I had an oil change and right after the engine blew out oil everywhere under the hood.I found the dipstick out about three inches. I checked the oil level and it showed just over full after all that oil came out. I believe the shop overfilled it. They are saying it happened because of a faulty pcv valve but we had no problems with the car before the oil change so that would be one hell of a coincidence.
My questions are can overfilling cause the oil blow out?
Can overfilling cause the pcv valve to clog causing the oil blow out?
Any thoughts? Thank you
OIL ALL OVER ENGINE
- Has thanked: 17 times
- Been thanked: 35 times
Did they install the oil cap? You would hear the PCV system in our cars whistling as a symptom of the clogged PCV. If you had no other symptoms before hand, I would say they did something to your car. Not sure about over-filling it but once cleaned up and oil topped off to the correct level were things solved? Btw, there is a recall on your model year's PCV, depending on the VIN. Check with your dealer to see if you qualify. If it's truly bad and you do, it's a free swap out to a new one.
