Hello,
Can someone tell me if the headlight switch is illuminated? It is dark along with the sunroof switch. I assume they both are backlit. Is that true? I appreciate your help.
1994 850 Illuminated Switch ID
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
YEs it should be lit up the 94s had the bulbs integral to the switches and when they burn out they have to be replaced- later ones you can change the bulbs- fill up on newer switches at your local picknpull
- skloon
I think it is 96 and up easy to tell as there is a little white button on the side that holds the bulb
Volvo 850 dash switch bulbs
- Has thanked: 311 times
- Been thanked: 817 times
Junkyard or check the Classifieds- Parts section here at MVS.
