P0154 Error code picture attached
- RickHaleParker
- Been thanked: 979 times
284: ECM-290A (P0154) Front lambda probe, bank 2. Signal too low. Permanent fault
Diagnostic trouble code (DTC) information
D2500824 Condition
Probe monitoring begins after probe preheating diagnostics are complete. Diagnostic trouble code (DTC) ECM-290A is stored if there is a fault in the front heated oxygen sensor (HO2S) or its wiring causing the signal to deviate from its permitted range.
The control module registers four different types of fault:
1.Signal too high
The control module compares the front and rear adaptation values. A diagnostic trouble code (DTC) is stored when the values deviate by more than 3%. Note! The fault may be in the front or rear heated oxygen sensor (HO2S) circuit.
2.Signal too low
The control module monitors the aging of the probe by checking its dynamics when switching between lean and rich mixtures. The diagnostic trouble code (DTC) is stored if the control module registers that the probe is operating too slowly.
3. Signal missing
The control module monitors cross-induction from the probe preheating. Diagnostic trouble code (DTC) is stored when cross induction exceeds the permitted value.
4.Faulty signal
A diagnostic trouble code (DTC) stored when:
the control module registers that the signal from the front probe is above 4.8 V for too long
- the signal from the front probe does not deviate from λ= 1
the signal from the front probe is showing a lean fuel mixture while the signal from the rear probe is showing a rich mixture
the signal from the front probe is showing a rich fuel mixture while the signal from the rear probe is showing a lean mixture.
Substitute value
The rear heated oxygen sensor (HO2S) control is disabled
Three-way catalytic converter (TWC) diagnostic is disabled
Possible source
1. Signal too high:
malfunction indicator lamp (MIL) lit.
D2500824 Condition
1.Signal too high
2.Signal too low
3. Signal missing
4.Faulty signal
Substitute value
Possible source
1. Signal too high:
- air leakage in the exhaust system
short-circuit to power supply or ground in the signal cable (+) or supply cable for pump current
defective heated oxygen sensor (HO2S)
- the cable for calibration current and the cable for pump current are short-circuited to each other
open-circuit in signal cable (-)
open-circuit in cable for calibration current
defective heated oxygen sensor (HO2S).
- Signal cable (+) and signal cable (-) short-circuited to each other
one of the cables for heated oxygen sensor (HO2S) preheating is short-circuited to the probe's other wiring
- short-circuit to supply voltage or ground in signal cable (+)
short-circuit to supply voltage or ground in signal cable (-)
short-circuit to supply voltage or ground in pump current cable
short-circuit to supply voltage or ground in calibration current cable
open-circuit in signal cable (+)
Active
Past
Past
- 304 Views
Last post by volvomadness
- 1637 Views
Last post by dgcantrellsr
- 12 Replies
- 2057 Views
Last post by FLXC90
- 1247 Views
Last post by yagger
- 915 Views
Last post by hu5ker555
