Engine light. Second time since I have owned the '99. Code read shows p0350, something with coil pack, according to O'Reiley. The codes in this forum jump from 349 to 351. Go figure. Was it a wrong reading or is p0350 right? Please steer me in the right direction.
Thanks
Shane
V70 Base 234,000 miles
First time for code p0350
Code P0350
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Code P0350
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Has thanked: 1848 times
- Been thanked: 1710 times
Here is a thread on the subject, but having read it not sure how much help it is. P0350 in a Primary/secondary ignition circuit fault but no explanation what that means. P0351-5 are ignition coil faults by cylinder.
viewtopic.php?t=13581
Only useful part is near the bottom where a hose was loose/split, but that was on a Turbo car.
obayha
Thanks Neil,
It not showing a P0351dash number puts it in an "I don't know" place. I changed out the radiator during the Christmas break, but the code did not show up until 1-8-2018. I do have two extra coil packs and will probably switch them out over the next warm day or two.
The car seems to have a different running pattern to it then it did before the engine light. Hard to explain, but I drive this 100 miles 5 days a week and it had a moment of odd and then 5 minutes later the light was on, yet it does not sound or act like it is running on any less cylinders.
1998 V70 T5 331,000
- Has thanked: 1505 times
- Been thanked: 3818 times
Thats the ignition coil series but weird that you get a P0350 with coil on plug ignition
The series P0351-0355 denotes missing coil signals, either permanent or intermittent fault.
I wonder if P0350 denotes a missing signal but is unable to determine correct cylinder?
Check your coils and grounds, including the M6 holdown bolt.
Check the 12VDC supply to see if it close to Battery VOtage.
- RickHaleParker
- Been thanked: 958 times
P350 means too many ignition misses in a count cycle. The P350 count cycle does not track which cylinders are missing ignitions , it just counts the sum of all the cylinders. P351 - P356 counts individual cylinders ignition. P0350 is the sum of P0351-P356. These are ignition misses not misfires. Misfire mean ignition happen but the cylinder failed to fire, ignition miss means it did not even try.
ECM-3200 (P0350), Ignition coil. Faulty signal
D2800348 Condition
The control module counts the number of ignitions in all 5 cylinders during a cycle (=255). During this cycle, each cylinder should have made 51 ignitions. The control module may miss up to 50 ignitions per cylinder before a diagnostic trouble code (DTC) is stored. Diagnostic trouble code (DTC) ECM-3200 is stored if the control module registers that more than 51 ignitions are missed.
Note: 50 ignitions per cylinder does not sound right. For a five cylinder that would be 250 out of 255. I'm pretty sure it should read 10 per cylinder. Which the total would be 40 out of 204 for a four cylinder, 50 out of 255 for a five cylinder, 60 out of 306 for a six cylinder. Code set at or above 41 for a four cylinder, 51 for a five cylinder, 61 for a six cylinder. Don't quote me on the four and six cylinder that needs to be cross checked. Rick Hale Parker.
Substitute value
D2800348 Condition
Substitute value
- Fuel trim disabled.
- Faulty signal:
loose connections in the connectors
defective ignition coil.
- the engine judders occasionally
the engine cuts out
the engine does not start
idling problems
driveability problems.
Exactly analogous to
p0301-P0305 being misfire on cylinders 1-5
And P0300 is multiple misfires
I missed that you got the codes read at an auto place. What you really want in these situations is the Volvo ECM codes like Rick reported above from VIDA or a higher end scanner
obayha
work in progress. The ETM was stuck shut yesterday as I was in start up heading to see a client. Would not rev past 2000 rpm's. ETM was stuck due to varnish, That's my term for gunk, around butterfly. Within 5 miles of driving after unsticking it the engine light was off. Came back on this morning after 80 miles of driving. Back off and then back on again. I will reread Rick's post again, as it sounds a lot like what is going on with it. The motor does jutter at stops. Has been doing that for a while. Any course of action with this information is welcome.
Shane
Shane
1998 V70 T5 331,000
Did you do a thoroughly cleaning with a hexane based Throttle Body Cleaner?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
As I read it, the code and dialog provided describe an electrical fault in the ignition circuitry, not air/fuel problem. Also, that it is wiring, not the coil failing. Tracing a ground fault sounds like a good path, or a brittle/loose connector in the coil wire spaghetti in the top of the head. I don't know how your car is, but I had to replace the coil harnesses on three different KIAs I stage-zero'ed for my kids to drive/trade-in over the past couple years.
Current Volvos:
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Also double check that you didn't squish one (or more) of the wires in the harness going to the coils or have any abrasions on them from rubbing.
I did. It results in intermittent misery until fixed. Toss all those wires in new split loom if you can. The old stuff was crumbling when I was last in there. If you have some bare wire, coat it in liquid electrical tape for a quick fix.
