Hi helpful folks.
I've red what I can on my issue, and I'm in a possible jam presently.
Winter week-end getaway in hilly Quebec, getting to chalet was near impossible.
Yes there was ice under the snow, nothing I haven't dealt with before. 4 winter tires.
Two adult daughters in back seat, wife and I in front.
Car would not climb a grade (winter mode) without spinning all 4 wheels.
Back down, try to take a bit of a run at it, nope.
Finally made it up the grade on my second try in reverse!
What am I not understanding?
Why could I only get up the grade in reverse gear?
BEFORE we leave our week-end retreat (yes we came down similar grades to the chalet)- Im asking any advice or help understanding this, and how to navigate out going forward (avoiding possible incoming vehicles)-on what or how to deal with this.
Thanks in advance.
AWD best in reverse? 2003 V70 2.5T AWD
Ok then, clearly I've stumped the members, never mind, weather warmed to a couple degrees above freezing, took the car out t o meet a challenge and it was fine up icy grades. No idea what happened last night, exceot it was more than a tad daunting. I notice almost 30 views from my op, with nary a suggestion or comment.
I've been a Volvo owner since 1971, (mostly wagons) and had pretty much every model going-my favourite being the 122 wagon.
Never been let down or perplexed until yesterday, which is why I felt the need to reach out here.
More likely you just found a better track the time You went up backwards.
There is a lot of expertise here but those folks don’t live in this forum, they are out enjoying their Volvos
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Yeh that.ljsommar wrote: 20 Jan 2018, 20:05 I think going up in reverse puts more weight over the front wheels which will give the best traction. I have experienced the same thing on my driveway with water over ice.
My bet is weight distribution.
I was going to buy some zip tie plastic emergency chains, couldnt find them anywhere and havent needed them.so..
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I remember driving a RWD back in the days, when I couldn't climb a hill, I would get a better chance climbing in reverse.
Without having been there, I'd place a bet on a combination of rear tires with more thread/less wear and, as already mentioned, a less slippery surface when you went backwards. You already mention ice covered by snow, which is already very slippery at temps near the freezing poibt, I'm surprised you even made in going backwards. Even Awd with quality winter tires (assuming not studed) won't climb a steep incline on ice.
yup to those answers.
although I did question the ratio between inertia and mass, and how it would make any difference if 4 wheels were turning...
Here's my personal conclusion, which will come as no surprise to AWD owners
(this is my first, and I only got it a year ago-ya I buy older cars)
it came with 4 "decent" tires on the alloy rims.
In this country, we have snow, lots of it, so we put snow tires on (spare set of rims) .
I get a 10% discount on my insurance if i have 4 snow tires on, in some provinces- it's law.
Anyways, previous FWD cars, it wouldn't matter if there was some difference (not huge) between the tire size.
I have a matched set on the front, and a matched set on the back.
with AWD drive vehicles it DOES matter that all four tires must be matched.
So I'm going with that solution, as i have now put the alloy rims with the tires back on the car (all matched).
I've done a good deal of research, and evidently the V70 AWD (3rd generation) is a very very good design.
Thanks for the help here, I do learn a lot by reading posts, first time poster.
Nice folks around here.....
a FWD Volvo with snows on all four will be fine on any road unless it's ice in which case nothing short of chains or studs will help.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Yes I was taught this too. It was explained to me that reverse was a lower gear than 1st and that was the difference. Juneoragex wrote: 21 Jan 2018, 18:02 I remember driving a RWD back in the days, when I couldn't climb a hill, I would get a better chance climbing in reverse.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- 4072 Views
Last post by Walru5
- 11 Replies
- 4451 Views
Last post by JimBee
- 1256 Views
Last post by nairbetrok
- 1026 Views
Last post by xHeart
- 329 Views
Last post by Ozark Lee
