Hard start/no start
patmoore72
- Year and Model: Volvo 2002 S60 T5
I have a 2002 S60 T5. Get a P0336 OBDII code and won't start/very hard starting. After removing the crank posit sensor, I discover there is a gash in the bottom of the sensor. When the car does start, it runs great. This car has a new flywheel, clutch, pressure plate and sensor. Also has new camshaft pos sensor. Sometimes even with the damaged cps, the car will start and run normally. I have put a new starter on it also, and a new battery. I have checked the reluctor disk for anything sticking out that might damage the cps. I have checked the resistance and voltage on all the cps units that I have taken offd and they all check oput fine. Ideas?
- RickHaleParker
- Been thanked: 979 times
Ideas?
P0366= ECM-5200 Engine speed (RPM) sensor.
Diagnostic trouble code (DTC) information
Condition
The control module calculates the number of teeth on the flywheel using the engine speed (RPM) sensor. Diagnostic trouble code (DTC) ECM-5200 is stored if the control module detects at least one tooth too many (Signal too high) or one tooth too few (Signal too low).
The control module detects the position of the flywheel for top dead center (TDC) using the signal from the speed sensor. Diagnostic trouble code (DTC) ECM-5200 is stored if the control module is unable to detect top dead center (TDC) on the flywheel (Faulty signal) or if the reference position for TDC is missing sporadically (Signal missing).
Substitute value
Signal too high:
Signal missing:
- Wiring and connectors.
Signal interference
Condition
Substitute value
- The control module uses the signal from the camshaft position (CMP) sensor if the camshaft position (CMP) sensor has been adapted
Variable valve timing control is blocked
Engine speed (RPM) is limited.
Signal too high:
- Signal interference.
- Incorrectly installed engine speed (RPM) sensor
Defective flywheel or ring gear.
Contact resistance in the terminals
Intermittent faults in the wiring for the engine speed (RPM) sensor.
Signal missing:
Contact resistance and oxidation.
- Engine difficult to start
Poor drivability.
Active
Past
Past
- 1075 Views
Last post by PS78
- 1590 Views
Last post by fontoledo
- 1440 Views
Last post by renegade343
- 6923 Views
Last post by Zeeko
- 25 Replies
- 8705 Views
Last post by AmericanT4
