We drove the S60 3 times for about an hour each time. When test driving the only thing I saw / noticed was It has a slight "warble" in the front end "probably a tire imbalance, or ice (it was cold and snowy and icy) if not I will fix it (this it the seller talking)" - it is still doing it - I think it is a BEARING - he is on vacation - he says he will fix everything when he gets back.
AFTER more or less falling in love with it, we bought it. It is in immaculate condition - dealer serviced for the first 100,000+ miles - one owner, everything looks good.
AFTER buying it - within the first WEEK or so we note:
* It has been VERY cold out - 0 to 30 degrees (F) - the car "lags" or "flares" when shifting from 2nd to 3rd - it only does this for a few blocks then becomes silky smooth and you can't even feel it shifting. I think on all of our test drives it was already warm. Seller says "I guess I noticed that, but they all do it, I wouldn't worry about it - we can try changing the fluid and see if that helps". This kind of freaks me out. I ordered a B4 servo cover and am planning on having him put that on too. IS THIS SOMETHING THAT WILL GET WORSE, EVENTUALLY ENDING UP MAKING THE CAR UNDRIVABLE?
* The coolant level low message came on after about a week - he says "I will fix it" - I think it is the WATER PUMP - he says the timing belt has been replaced - the car has 190,000 miles and if changed at 120K, that would leave 40-50K left in the timing belt
* The day after the coolant level low light came on, I went out to start it in the morning and it freaked out, coughed and sputtered, flashed "REDUCED ENGINE PERFORMANCE", the check engine light came on etc, etc. I turned it off, and then turned it back on - same thing. This was on a Sunday. Let it sit. Still did the same thing Monday. Got a cheap OBD checker at Wal Mart - pulled code P2111 - RESET CODES. Car started right up and ran PURRFECTLY...
Drove it around. Turned it off again and started again - got P2111 again - sputtered - RESET - ran perfectly. A few days later now it seems to work fine again. This code I understand means "ETM" - $350 + install (he said he would install if that's that it is.
This ETM or whatever thing happened after I ran the car through the car wash and then took it out on the interstate and drove at 70-80 MPH for awhile trying to figure out the "moan/whoosh/warble in the drivers side front". Car worked fine that night (a Saturday night). Then on Sunday it was in the 40's or 50's outside (up from below freezing) and it was FOGGY and everything was wet and melting. Could the dampness have something to do with it?
This is completely UNACCEPTABLE in my mind - I do not want a car that decides it needs to be in "LIMP MODE" and barely run for NO REASON. What is up with this?
Is there a software update for this? Should I just throw a new ETM into it? Should I take it to a DEALER and have them "diagnose" for $50-150? Is it something else? Will it do this again? Everything under the hood looks like it is NEW. How do I get the $&&% dealer to apply updates to the car? They said - $50 and we will plug it in and give you the FREE updates [once a year?] but not the updates related to things going on. There is one dealer 30 miles away that wants $130 and another 50 miles away that wants $50. $*$%*%(@@
Another thing going on is the GAS GAUGE - reads 0 intermittently when tank is anywhere between about 1/2 and full - there is a TSB about this - there is a software update - but I have t PAY them to "diagnose" and then pay EXTRA to get the $#$(# update???? WTF - I did not know about all of this...
ANOTHER thing is the KEYS. He only has one key. I made him get me another key (which he hasn't done yet). The freaking keys are a nightmare - $$$$$$$$$$$$$$$$$$$$$$$$$$$
This is nothing like my 98 V70 which has started right up every day for 15 years. The keys for that are like $30
Should I make the guy buy it back from me or keep it? I am willing to put up with a little bit as long as I end up with something that is reliable and won't strand me or my wife out in the middle of nowhere at a scary truck stop after filling it up or something for no reason.
Thoughts? Should I not expect a car this ago to be able to drive for a few hours on the interstate and not "shut down". Mechanically it is perfect. It is all of this SOFTWARE and SENSORS freaking the computer out that appear to be the problem. I think the transmission thing has an update too? Not sure. How can I find out - the dealer won't TELL ME...
Is there some dealer that I can call to get the UPDATE HISTORY who would help me figure out what updates might be applicable to my VIN. This is all a bit much. My other choice was a Camry (should have done that but couldn't bring myself to it).
THANKS!!!!
