Aftermarket lower control arm is shorter?
1volvo2many
- Year and Model: 2001 V70 XC
- Has thanked: 2 times
Hi there. I've purchased a Lemforder lower control arm (front, 2001 XC70) and it's a good inch and a half shorter than the original. Is this normal? Will it harm anything? Thanks.
Cookie-the-Swede
- Year and Model: 2003 S60 2.5T AWD
- Has thanked: 1 time
- Been thanked: 4 times
If they are 1.5" off on each side, there HAS to be a problem.
A 3" narrower track width in the front end would look obvious.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
By "shorter" you mean the original 'reaches out' more?
The mounting points (rear stud and forward cylindrical bushing) are the same, yes?
I'll bet they sent you a control arm from a non-XC model.
1volvo2many
Thanks for the replies. I believe their site is incorrect. I purchased a set of two for the front listed as matching the X/C. However, when you search for each one individually you get a different part number (Lemforder).
