02 XC70 shuddering at idle Topic is solved
I was going to get an oil change today. That's where I was headed when I turned the car on and it was shuddering almost as bad as I was after I noticed it.
I checked the air filter before I got in, snapped it back in and turned the car on. Yesterday, it was fine. Or it wasn't bad enough for me to notice, if it wasn't fine.
It stays pretty comfortably at 1000rpm according to the Rev meter, but it seems like the rpms rise and fall, always culminating with a shudder that shakes the whole car at the peak.
I haven't found anything online that matches what my car is doing exactly. No recent repairs or shop visits other than a couple new tires in the back. I'm baffled.
I'm happy to provide as much info as I can, thanks in advance for all your guys' help
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The idle seems to high as well. Has it always been like that? IIRC the NAs idle at about 800 and at least the 2.5T at 650, I'm guessing the 2.4T should be about the same.
- Rattnalle
And I'm guessing it's a 2.4T since it's an -02? Never owned one of those, just test driven, so I'm not sure about the idle but it should at least be as low as the NAs which have been around 800 since the 850 for the straight 5.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
What do the codes tell you?shafe36 wrote: 15 Feb 2018, 12:54 Yep, 2.4. Reading around, it looks like it is running high. I suppose more symptoms makes it a little easier to diagnose. I've heard a million and one different diagnoses so far
Cars are way too complex to diagnose by symptom. You will typically take 2-3 hours to check subsystems for faults to find what's causing a problem. It's 2-3 hours of your time or the mechanic time, who might be a bit faster.
Here I would start with finding the vacuum diagram and removing and checking each hose for splits tears and holes.
When were the ignition parts, coils and plugs, last checked or replaced?
Thanks for trying to help guys! I changed the plugs and put some fuel system cleaner in Sunday. I accidentally bumped the air filter and, lo and behold, the problem went away for a second. Looks like the MAF was bad and choking out the rest of the engine. I unplugged for a few minutes and it ran like a dream! The RPM even went down to around 800 at idle. New one is on the way! All is well. Thanks again!
- 11 Replies
- 1638 Views
Last post by Esjay
- 869 Views
Last post by r_ziots70
- 1094 Views
- 672 Views
Last post by LostFoam
- 62 Replies
- 10990 Views
Last post by EngineeringBloke
