98 S70 T5-M; will not go into any gears
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
Hello;
1998 Volvo Volvo S70 T5-M; I cannot shift into any gears with out (grinding). What should I do first?
Thank you.
98 S70 T5-M Brick for life
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
How does the clutch feel? Is your brake fluid reservoir at the max line? How many miles on the clutch and what is your driving style?
Juan62
Post by Juan62 »
The clutch padel goes all the way to the floor (no resistance).
The brake fluid is max line (but I think I have a leak). I used to have to add brake fluid every two weeks of driving (M-F) work only.
Normal driving, work (M-F).
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
+1, Check the fluid in the brake fluid reservoir. Then have the clutch checked.
rspi
Post by rspi »
If the slave cylinder is leaking and can't build pressure, it won't work.
Juan62
Post by Juan62 »
What is a slave cylinder and where can I locate it to check for any leaks?
rspi
Post by rspi »
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Juan62 wrote: 20 Feb 2018, 16:32 What is a slave cylinder and where can I locate it to check for any leaks?
Depend on your vin, you can have an internal or external salve cylinder.
85 GLH, 367 whp
00 Insight, 72 mpg
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
The slave cylinder turns fluid pressure into mechanical motion. It is at the transmission end of the clutch hydraulic line. It may be inside or outside of your clutch housing. On a 98 it "should" be outside. That makes it easier to repair.
Have a helper operate the clutch pedal, while you look for motion at the clutch release lever that goes through the side of the transmission/clutch housing. If there is no movement, your clutch hydraulics are the problem.
PS I accept donated broken Volvos :lol:
Current Volvos:
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
A slave cylinder is a hydraulic cylinder that disengages the clutch when you push down the clutch pedal.
The Clutch Master cylinder is on the firewall. The Clutch Slave Cylinder is on the front edge of the transmission. Just follow the hydraulic lines from the firewall to the transmission.
There is more then one type, if you end up needing one, your need your Chassis number to figure out which one. Your Chassis number is last six digits of your Vehicle Identification Number (VIN) with any leading zeros removed. (i.e. 000123 = 123). You can find your Vin number on the plate in the corner of the windshield or on your title.
Active
Past
Who is online
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 35 guests
