1995 850 Turbo Sedan For Sale
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 12 times
Post by alschnertz »
1995 850 Turbo Sedan, automatic; 258,000 miles; one family owned.
The car was always a daily driver and has never been modified. It's just a plain old stock 854T.
Body is very good with little rust and few scratches. It is not dented, the glass is all good but one of the front signal lights has a crack.
The right front passenger side door stop was welded many years ago. I added extra support to the left side door stop when I bought the car from my sister in 2011. The trunk gasket sometimes leaks near the latch.
Interior is good though the front seat leather is cracked and some seams have split. The dash pad is not cracked. The headliner is ok. It's not sagging, but is discolored is some spots. The shifter handle has a crack. The driver's seat memory works and the seatback reclines as it should.
Engine runs well and has been maintained at factory intervals or more often. I've always used factory or OEM parts. Valve seals, timing belt and PCV system were serviced at 244,000 miles.
Transmission shifts well and has had regular fluid changes.
Repairs needed include;
Right side trailing arm bushing;
ECC light is blinking and the blower is not responding to the switch. The blower motor has been tested and does run;
Glove box door latch broke and I removed it. Have the door, but it's not installed;
CEL was on with a 4-4-3 code (cat. efficiency).
The muffler and tailpipe with hanger need replacement. The catalytic converter-to-muffler connection has been repaired before but now leaks again;
Tires need replacement and 2 rims are scarred.
I've really enjoyed this car but can't justify doing all the repairs when I have too many other projects going on.
I hate to scrap it.
The car is not registered or insured at this time and is located in western Connecticut.
$500.
LF 3.jpg (198.73 KiB) Viewed 304 times
RR 3.jpg (172.91 KiB) Viewed 304 times
'84 Prelude
'06 MPV
'13 Ford Focus SE
