FS: 2002 Volvo V70 T5 in Wilmington MA
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
You know as much as I do after reading this. This is an email I got from a guy named Mike. Contact me and I'll give you his phone number. You take it from there.
I'm looking to sell really cheap, the car runs and drives, it's kinda fast too, it needs a little work nothing major, it's very sharp looking, factory 17"wheels with resent tires , looking to sell fast.
I think it has 170k on it , auto trans , dark red on tan, driver seat is worn and needs window track on right front, it has a new mass airflow sensor but it's unplugged so it will run , Im thinking there's a vac leak somewhere all the vacuum lines are weak looking, the heat shield on the muffler is making noise but no exhaust leak yet , the shocks are on the way out , the tires are fairly new but I can just start to feel the shock wear in the tire when you slide your hand on the tread , front end is tight, has a small oil leak, I drove it down the road in back shifts fine I got on it and was surprised it was as fast as it was lol , I put a new battery in it , if there anything you need me to look at let me know I'll check it out , pretty clean underneath.
Also -> Amazon link
