So this noise started up yesterday sometime while driving. I pulled over and had a look and couldn't see anything visibly wrong and have driven it 30km more or so. It seems to be coming from the serpentine belt/PS pump/AC compressor area but I can't pinpoint it, and I'm wondering if anyone has heard something similar. It's only audible while stopped, once I start driving I think road noise drowns it out. Tough to tell, but I don't think it's RPM-dependent
Background on the car: 1996 850R, 245,000km, toooons of maintenance in the past 15,000km. Serpentine belt/timing belt/WP, etc, etc all replaced at 231k. Ignition system is all less than 20k, PCV has 16k, oil pan seals, oil cooler line seals and oil cooler thermostat seals done 4k ago
If anyone has ideas, I'm all ears! My first impression would be the power steering pump or one of the serpentine belt pulleys is on its way out.
Odd noise coming from serpentine belt area/front of engine Topic is solved
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
1996 854R | M56H | 16T | 274k | BC, Canada
- Has thanked: 2202 times
I would suggest (based on not being able to hear it clearly) that is may be one of the pulleys bearings in the serpentine belt area.
As abscate and others suggest usually, try a piece of hose held to your ear as a probe, but be VERY careful around the moving pulleys and belt. Also, if you have a Harbor Freight or likes around you may be able to pick up a cheap mechanics stethoscope and try using that, but same safety concerns.
I find identifying the bearing on that belt path difficult to hear as so much noise travels through the aluminum housing supporting the majority of the components. Pull the serp. belt and see if the issue goes away. Perhaps with the belt off, spinning each pulley bearing may be more fruitful.
Good Luck!
Good Luck!
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Hopefully noise will go away when serpentine belt is removed. As Neil suggested, go from there, looking for something that turns which has play, or is noisy. Next step might be to remove TB cover and inspect everything that moves and is belt related there, though sounds like alternator area is source of noise. Looks clean under that hood!
sventastic
scot850 wrote: 12 Apr 2018, 16:08 I would suggest (based on not being able to hear it clearly) that is may be one of the pulleys bearings in the serpentine belt area.
Good Luck!
Thanks for the input guys! Much appreciated.rguzz wrote: 12 Apr 2018, 16:59 Hopefully noise will go away when serpentine belt is removed. As Neil suggested, go from there, looking for something that turns which has play, or is noisy. Next step might be to remove TB cover and inspect everything that moves and is belt related there, though sounds like alternator area is source of noise. Looks clean under that hood!
The plot has actually thickened a bit, but this may help narrow things down, since it eliminates any rotating parts and belts. The noise continues to be present when the engine is off, and the key is in position 2.
New video with engine off
Also if you guys want to nerd out on a Volvo story here's my thread from VS
http://volvospeed.com/vs_forum/topic/17 ... r-project/
- Been thanked: 504 times
- Probably dry bearing(s) at 150K miles...
- As others have said, remove the serp. belt.
- Then spin each component: idler and tensioner pulleys. If they free-wheel and keep spinning after you release your fingers, they are bad. Shake them sideay to see if there is any play. Then spin AC Pulley. Then spin alternator pulley.
sventastic
How could it be a bearing? In the latest video I posted above, the serpentine belt is not engaged and there's nothing spinning, the engine is off yet the noise is still present.cn90 wrote: 12 Apr 2018, 18:57 - Probably dry bearing(s) at 150K miles...
Not sure if it's worth noting that my fuel pump whines somewhat loudly
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I recall a guy several weeks ago had an air pump that was running and making noise with just the battery on. It lives somewhere near the throttle body and transmission?sventastic wrote: 12 Apr 2018, 19:27How could it be a bearing? In the latest video I posted above, the serpentine belt is not engaged and there's nothing spinning, the engine is off yet the noise is still presentcn90 wrote: 12 Apr 2018, 18:57 - Probably dry bearing(s) at 150K miles...
- ZionXIX
Found the thread: viewtopic.php?f=1&t=84322&p=462504&hilit=noise#p462504
sventastic
Thanks for the link! It appears the noise was coming from the headlight wiper motor, just like in that thread. I unplugged it and turned the key to position 2 and the noise did not come back. Started the car, still no noise. Plugged the motor back in and the noise did not start up again, so we'll see how long that lasts. Both headlight wipers still work properly when cleaning the windshield. I wouldn't call this fully solved quite yet but I think there's a good chance that's all it was.ZionXIX wrote: 12 Apr 2018, 19:44 Found the thread: viewtopic.php?f=1&t=84322&p=462504&hilit=noise#p462504
- Has thanked: 311 times
- Been thanked: 817 times
LOL at "probably a bearing" when the noise persists with the engine off. Sometimes actually reading the thread is just too much work ...
If the wiper motor gets jammed you can reset it by unplugging and plugging back in, sounds like you found it and fixed it. Well done.
- 7618 Views
- 2539 Views
Last post by bmdubya1198
- 20 Replies
- 17465 Views
Last post by Hurtfeelings
- 597 Views
Last post by Eddystone
- 2379 Views
Last post by jimmy57
