I am attempting to do an oil change on my 2014 XC60 T6. I removed the engine "batwing" and moved the brake reservoir but there is still not enough clearance to get the oil filter out from above. The lines on the reservoir are too short to move it enough for clearance. Has anyone done an oil change on a 2014? What am I missing?
Thanks,
Kevin
2014 oil change Topic is solved
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
I just saw your post today and I'm sure you've figured it out by now, but for posterity...
The quote below is from http://www.volvo-forums.com/t46417-how- ... filter.htm
"While the oil is draining, locate the oil filter housing in the engine compartment on the passenger side below the power steering reservoir. Look for a black plastic cap with a big hex nut on top. There's little room to work. Detach the power steering reservoir and move it to the side. Do not detach any hoses from the power steering reservoir. To detach the power steering reservoir, you'll need to wedge a small flat head screwdriver under the small clip holding the reservoir. There's a catch in the hole of the clip so wiggle the clip side to side and it should slide right off. Make sure you don't drop the clip in the engine compartment. You'll need this clip to re-attach the power steering reservoir later. Slide the reservoir off the bracket and move it to the left. You'll now have just enough room to remove the oil filter. Clean the area around the oil filter cap and housing with a clean rag. You don't want to get any dirt in the oil filter housing when you remove the cap."
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- 11 Replies
- 15923 Views
Last post by RossJonnes
- 1668 Views
Last post by E Showell
- 276 Views
Last post by azureblue
- 3650 Views
Last post by oragex
- 1942 Views
Last post by Biggertuna
