I have a 2011 XC70 AWD that had a vibration in the driveshaft (propeller shaft) . I removed the shaft and it had a bad carrier bearing and possible bad rear cv joint. The shaft is built so that the carrier bearing cannot be removed. If a shop could to this work is the bearing available separately? Volvo vida also says that the rear cv joint is not repairable but It seems that the part is available and can be done.
Any thoughts would be greatly appreciated
Thanks
Mike
XC70 driveshaft repair or purchase
- 922 Views
Last post by jonesg
- 1797 Views
Last post by mrscullini
- 1463 Views
Last post by carboncow
- 844 Views
Last post by njutila
- 15 Replies
- 2296 Views
Last post by Rattnalle
