2003 S40.
Can someone tell me about this? I took the cover off to change coolant sensor and found oil pooled by spark plugs. No idea where it's coming from or where to start looking.
Kevin
2003 S40 oil leak
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Clogged PCV is possible.
Search "glove test" to help with your diagnosis.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
jefe
- Year and Model: 2001 Volvo V40
- Been thanked: 3 times
Yea, could be clogged PCV definitely.
I also had this issue with oil pooling up. My PCV was clogged, but the cam seals were leaking along with the exhaust cam sprocket for the timing belt. All that of course lives under the plastic covers for the spark plugs and timing belt and means over time, the oil splattering everywhere on the inside of those covers has to go somewhere. For me, it was on top like yours as well as down the side of the engine and underneath.
Was not a fun clean up job.
Kaman36
- Year and Model: 2002 S40
Did you find the oil leak, cause I've got the same problem. Mine seems to be coming from the return on the oil separator but not so sure, I even replaced the vvt solenoid because it was definitely leaking there, but I've still got a leak.
Well I still get the oil pool in spite of the pcv flame trap replace and all that. Same thing. Digging in and pulling plugs to see what else I can find. More help appreciated. Engine also blowing blue smoke.
Plugs don't have any oil on them. Pooling seems to be towards the passenger side.
Jefe I think it's as in your case - looks like around the exhaust cam sprocket. How tough a job is it to replace those seals?jefe wrote: 16 Jun 2018, 21:31 Yea, could be clogged PCV definitely.
jefe
If you were just doing the seals, it's probably a 4 or 5 on a scale out of 10.
Not that it's tough, just time consuming. In order to change the seals, you have to lock the cams down which requires a special tool. In order to do that, I removed quite a bit of things from the driver side of the engine to access the rear more easily in order to lock the cams down.
I can't remember if I had to raise the engine up slightly on the passenger side in order for the correct tools to fit in the space needed to remove the intake and exhaust cams. If I did, that requires removing the passenger side motor mount.
I would suggest changing the front and rear seals all at once and if your exhaust cam has any oil on it, then it's probably leaking as well. I put my engine back together before realizing my exhaust cam sprocket was leaking too and had to do it all over again.
FYI, for my V40, there is no rear seal for the intake, only the black metal/rubber plug.
- 1600 Views
Last post by SuperHerman
- 1809 Views
Last post by oragex
- 13 Replies
- 3222 Views
Last post by MadeInJapan
- 1892 Views
Last post by Richouser
- 972 Views
Last post by vtl
