transmission won't go if a little hot
dieterschmied
Year and Model: S60 2.4T 2002
Post by dieterschmied »
I Have a Volvo S60 2.4T 2002.
It moves when cold but when in gets warm after a few minutes it stops. If I leave it set for a short time , it will move again.
Is this a common problem? How do I repair?
Is there a way to have an onboard computer determine fault? If so, how?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Pull the transmission dip stick and check the color of the transmission fluid, report back. If your in good luck, the fluid is breaking down and replacing the transmission fluid will resolve the issue.
Active
Past
