Seems like my power steering cap won't shut tightly anymore. It turns and then clicks and then just keeps turning. I'm worried this may be causing a leak.
Any ideas what I can do to secure it?
Power steering cap loose
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
There's a thin plastic washer which may have deteriorated.
Cutting an annulus from plastic of an appropriate thickness is one thing people have done.
Clorox bottle?, clear salad container?,
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
There is enough pressure in the "low pressure" side of the power steering system to move the fluid out of the works, and back into the reservoir. The pump sucks fluid from the reservoir, so as long as it is not empty, you are in no danger of a mechanical failure.
If I were in your shoes, I'd get a large size hose clamp, and clamp a small section of rag over the cap and around the neck of the reservoir. Take care to not tighten too much, you don't want to crush the neck. The idea here is to hold the cap down, and to soak up any fluid that comes out. So, assuming you clean the neck off before you start, the cloth will be an indicator of a leaking condition, if it is damp, you are leaking.
But order a new cap - its $8, so why mess around with it when it can ruin your whole weekend if it (somehow) fails catastrophically?
https://www.fcpeuro.com/products/volvo- ... p-30680253
If we stop things that leak from leaking, all the fluids that make the car go stay INSIDE the car, and the garage stays clean.
Cars that leak nothing at all live far longer than cars that have a greasy underside.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
- 2401 Views
Last post by erikv11
- 1327 Views
Last post by 122sPhil
- 312 Views
Last post by br0dy519
- 492 Views
Last post by kevins s70
- 614 Views
Last post by tryingbe
