New engine, valve job, or punt?
My 2004 XC90 2.5T AWD w/193,000 miles has a burned valve, apparently. I was driving on the interstate and the CEL came on. Lost a cylinder, hoped it was a coil, but, sadly, no. I love the car. What would you do? Should I have a valve job done, replace the engine with a used one, or part it out and move on? So annoyed and sad. I could kick myself for not pulling over immediately.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Valve job or cylinder head swap, drive it for another 200k
Current Volvos:
- SuperHerman
- Been thanked: 207 times
Pulling over would have not helped if you have a burnt valve so don't feel bad.
If you have the vehicle properly sorted then you may want to keep the car. You need to price out the cost of both projects (new used motor or head rebuild) and move forward. If you can do it yourself then fix the head. For about $1000 you should have the top end head and seals, timing belt, water pump and everything else fixed if you do it yourself. I would also rebuild the turbo while there.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
What's the rest of the car like? If it's nice, and you like it, then I'd fix it. Since you didn't mention them, I'm guessing the bottom end and transmission are fine, so removing the head and doing a valve job are the likely fix. For what it's worth, my 850 has essentially the same engine, and it's over 300k miles now.
On the other hand, if the car is junky and you're looking to get rid of it, then this is a good excuse.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
