Heh guys.
Just went out to look at a potential used V70 to purchase for myself and as I was taking her out for a test drive I noticed that the speedometer (digital) was seemingly stuck at zero mph, even though I was traveling at around 35 mph.
Can anyone tell me if this is a cheap fix or is it going to add several hundred dollars to the after purchase price?
2001 V70 (Odometer doesn't work)
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 158 times
- Been thanked: 6 times
- Has thanked: 2211 times
If this is the next generation (P2) then you are in the wrong section for an answer although some folk may have both cars and can answer. I know the speedo unit is know for problems with the P2 generation cars. There are companies that repair then but don't know the cost. Try Xemodex as I think they fix those issues.
Does everything else work? If it is just the speedo then there may be an issue with the ABS sensors/unit.
Mr. Detail
You are correct Neil. I did post in the wrong category. Will re-post. Thanks.
- Has thanked: 1611 times
- Been thanked: 4075 times
Locked , see P2 forum
