Tailgate latch handle
BrianV70
Year and Model: 2000 V70 XC AWD/SE
Has thanked: 7 times
Post by BrianV70 »
I've searched a bit on this; not sure my issue is the common failure of the whole latch mechanism and tailgate being stuck.
My problem is that the outside handle above the license plate doesn't always engage to open the tailgate. The electric lock works OK (a little slow, may be binding somewhere as the little knob inside is slow to pop up). 1/2 the time however, when you squeeze the handle, its not pulling on anything.
Thoughts?
Thanks!
2000 V70 XC/AWD SE
configsys
Year and Model: V70R
Has thanked: 2 times
Been thanked: 5 times
Post by configsys »
I just replaced my latch assembly last month. Got a replacement from the junk yard. The outside handle moves a metal rod which pushes on the inside latch assembly. In fact, when I replaced mine, it wouldn't open from the outside and it was a good thing I grabbed the entire latch assembly to include the 2 metal rods since my original one was about 3mm shorter and wasn't fully engaging the latch. You may be able to just straighten it out and see if that helps.
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
BrianV70
Post by BrianV70 »
Cool - Sounds simple enough. I think step one will be to just remove the cover and see whats going on.
Has thanked: 1609 times
Been thanked: 4065 times
I had my spare old one in my hand to throw out today and thought
...someone on MVS needs this...
The latch doesn’t work, the rest of the locking hardware does
Pm me
configsys
Post by configsys »
You may want to order one of those tailgate panel repair kits from FCP Euro. I broke just about all those plastic guide pins when I removed mine.
'16 S60 AWD
'17 S60 (totaled)
'13 XC60 Polestar
'12 S60 T5
'04 XC90 (sold)
'02 S40
'00 V70R
'93 850 GLT (sold)
'13A DICE/VIDA
BrianV70
Post by BrianV70 »
configsys wrote: 12 Jul 2018, 10:14 You may want to order one of those tailgate panel repair kits from FCP Euro. I broke just about all those plastic guide pins when I removed mine.
Mine are already broken. Prior owner screwed it on with sheet metal screws!
