I'm having issues with a friend's C30 1.6D 2010 model.
The car is in limp mode, no LED/error message on the dash. VIDA gives me the following error code: "ECM-2A30 Particulate trap signal too high".
Problem is: the DPF, pressure sensor, hoses and additive fluid are all brand NEW, replaced less than 3.000km ago for the DPF and less than 100km for the sensor.
When I try a forced regen, I immediately have the "operation failed" error message. The values regarding the DPF pressure are within the norm (3-4Hpa at idle, +-30Hpa when pressing the throttle).
I also have a constant reading of the DPF temperature sensor: no matter the conditions, it stays at 97,62°C.
Here's a screenshot from the frozen values:
Do you think that the ECM is at cause here?
Thanks for the help!
