850 Rescue
I bought this old girl at auction momma wants to run it. The problem is I can't get the compressor for A/C to turn on nor can I get the auxillary fan to work also. Any feedback is great. 1995 850 GLT with 115K.
- RickHaleParker
- Been thanked: 979 times
Auxillary fan won't come until it is needed. Are you getting the engine hot enough it is needed?
Turn the A/C on full, disconnect the wire harness from the A/C Pressure Switch. With a paper clip jump the wire harness. If the compressor clutch engages the A/C is low on refrigerant and may have a leak.
Do not attempt to run the A/C with the paper clip in place, keep it in place just long enough to do the test, then remove it.
Active
Past
Past
Thanks will try that tomorrow. I let it run for about 20 minutes thought that was long enough seeing it's 85 and humid was going to try and jump that also from reading other posts. I was thinking but not sure if the TCM was bad would that effect both systems?
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
The other thing very common with those is the compressor clutch gap getting too big. Read up on the ghetto fix with zip ties or bread clips. It´s worked like a acharm for years on 2 of our 850ies.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
Does the gap getting too big cause the compressor to never engage? My clutch has stopped engaging entirely as well, and just recently this week got the system refilled but the compressor still did not click on.
1996 854R | M56H | 16T | 274k | BC, Canada
- Been thanked: 4068 times
If it’s is really fat , yes, the compressor will never engage. Probably something like 0.8mm or bigger
You can just pull the connector of the compressor and apply 12 volts to see if it clicks, engine off.
- Has thanked: 311 times
- Been thanked: 817 times
See Rick's post: likely the AC is low on refrigerant and that's next on the list.
I'd also check the clutch gap on the AC compressor. If it is huge, shrink it down with zip ties or mechanic's wire.
- RickHaleParker
I tried the paperclip jumper and the compressor will kick on. What's next.
It is low an refrigerant. It needs to be pumped down (evacuated) and checked for leaks. If no leaks, a refrigerant recharge.
Active
Past
Past
- Has thanked: 2203 times
If re-filling it is worth having dye added to the refrigerant. If there is a leak then this will help identify the source. 2 main issues are stone damage to the condenser, and a rust hole in the evaporator. 850's mostly did not come with a cabin filter so leaves and other stuff can get down into the evaporator and then sit and fester with damp which rusts out the evaporator.
- 68 Replies
- 9587 Views
Last post by manovlov
- 1139 Views
- 40 Replies
- 4785 Views
Last post by E Showell
- 94 Replies
- 10786 Views
Last post by bmdubya1198
- 753 Views
Last post by Oly850
