1997 850 Charging issues
wilslap3
Year and Model: 1997 850 & 2001 S40
Post by wilslap3 »
So, wondering if anyone can give me any ideas.
The wagon started not wanting to turn over every once in awhile, and upon further inspection I was only getting about 13.2 volts. When I turned on the AC or the brights, it would drop down to 12.4 volts. So this obviously wasn't enough for charging, got the battery tested, came back good, voltage regulator came back bad. Figured since those dang voltage regulators were so expensive, I would just order a refurbished alternator. So went ahead and replaced the alternator. Same thing though, 13.2 volts. So I yanked it out, and took it to the local shop to have them bench test it. Came back faulty. So I figured just some bad luck, ordered another, but this time I had it tested before I put it in, and it worked great on the bench test. After installing the second one, still 13.2 volts. I've cleaned all of the connectors, and replaced the serpentine belt, but still nothing.
At this point just looking for some suggestions, I've done some web searching but haven't had any luck. Any ideas would be greatly appreciated! Thanks!!! :D
Has thanked: 1610 times
Been thanked: 4065 times
Put the battery on charger overnight, then load it for 30 seconds with headlights, then measure voltage and report.
How old is it in service?
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I agree with the above suggestion to test the battery.
In addition, it would be a good idea to measure the voltage drop across the positive battery cable between the battery post and the starter and the alternator. When the system is running, the voltage drop should be less than 0.2V. If the voltage drop is higher than that, the cable, crimps or connectors are faulty.
