Lightning strike
jmiller5104
- Year and Model: 2016 XC90
So my XC90 got hit by lightning and is electrically completely dead. Anyone know how to get into my glove box??? Please help.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Pull the trim just above glove box and use a coat hanger wire cut a few inches long with a 3/8 to 1/2 inch long section bent 90 degrees. The center screw for glove box top has a slot to the left of it. If you stick the hook you've bent on the wire straight in 3 1/2 inches with hook up and then turn the hook to the left 90 degrees and pull to rear of vehicle you will catch the release lever and it will open.
That trim can be removed with a small screwdriver or other flat small prying tool by inserting on RH end and prying rearward. One it moves back then go to the left and work it off.
- 462 Views
Last post by EgbertV70
