Bought a serpentine belt for my v90 from Auto Zone, and tried for a good three hours to put it on to no avail (it was too small). Thought maybe I got the wrong one so I double checked with Auto Zone, also checked with Volvo, and Advanced Auto Parts. All said it was a 69 inch belt. Won’t go on. Thought maybe I rounted it wrong. Nope was sent the route by Volvo and was correct.
Am I missing something??
Serpentine belt for a 1998 V90, will not fit
It was pulled back and I even inserted a screw to keep the tension off the belt. I’m going to try a larger belt that is 70.5 inches instead of the 69.0 that I have. I don’t know what else to do. I appreciate your help and would gladly hear any other suggestions you might have.
dm635
- Year and Model: '96 965
- Been thanked: 14 times
I just went through my hand written service Log I keep on my '96 960. Actually I keep a service log on each car in my small fleet. Back in the spring I replaced the serpentine belt on the '96 960. The brand and part number was :
Contitect 6PK1642
Believe it came from FCP, or EEUROPARTS.COM.
Way back when when I had a '92 & '94 960's the size was smaller. And I believe the difference was due to a different sized tensioner pulley between the early and later models. The part number listed above was a perfect fit for the '96..
Contitect 6PK1642
96-964
09-V70
05-325i
86-635CSi
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945, 91-780t, 96-960, 98-XC, 91-745,
09-V70
05-325i
86-635CSi
dm635
Contitech 6PK1642
Way back when when I had a '92 & '94 960's the size was smaller. And I believe the difference was due to a different sized tensioner pulley between the early and later models. The part number listed above was a perfect fit for the '96.. Contitech is OEM as far as belts go. Use for timing belt as well. Never a problem.
Contitech 6PK1642
96-964
09-V70
05-325i
86-635CSi
09-V70
05-325i
86-635CSi
- 30 Replies
- 8518 Views
- 20 Replies
- 17344 Views
Last post by Hurtfeelings
- 26 Replies
- 9462 Views
Last post by patsaison
- 22853 Views
Last post by mechanic
- 21 Replies
- 5278 Views
Last post by viper69
