The issue:
- Rear driver side passenger window completely inoperable from the drivers console (motor does not engage up or down)
- Rear driver side passenger window will not go up from rear driver side passenger switch but is now stuck down (motor does not engage going up, does engage going down)
- Checked fuses
- Cleaned contacts on both affected switches
- Tested for ground and voltage at motor on both terminals as well as at switches
- Tested with known good switch, same result
- Replaced relay
- Replaced motor
