My 2001 V70XC has a problem where it cranks, but won't start. When I turn the key enough to power on the electronics and gauges, I get a Check Engine light and a low fuel light (the gauge pointer isn't all the way down in the red zone). I ordered a OBDII reader for my Android, and the Torque app shows this:
It only shows this, the app doesn't say any other error codes or anything else. I'm not too knowledgeable about cars, so I don't what can be causing this? Is it really a low fuel problem that can be solved just by putting more gas into it? Or is there something else wrong here I need to fix. It says something about temp, but its summer now, and while it might be cooler than normal due to rain we've been getting in MD, it hasn't dropped as low as it does in the winter, when this car acted perfectly fine.
Before getting the OBDII reader, I tried to switch around the Fuel Injection Relay with Floodlight Relay to check and see if that was problem, like I've all over the place, and the Floodlight Relay didn't work in the Fuel Injection Spot (not sure if thats supposed to work, but that is the only info I've found pertaining to my specific model).
Any help would be greatly appreciated, thank you.
