Can anyone tell me how the fuse box lifts up and whether or not the relay is something that just pulls straight out ?
Thanks.
Blower Motor Relay - how to access this under the fuse box??
There are two levels of relays on the 1999 2000 models - some are accessible under the flip cover (no tools) and then a bunch more under the layer after you remove some Torx screws.
I think all the relays just pull up firmly to come out.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There is a lower level. The front of box slides up, the + terminal nut has to be unscrewed. There are tabs around perimeter of the top layer you push away from the edges they clip over, and then lift the top up.
Disconnect battery before doing all of this.
- sanfelice
- Year and Model: 00 VR;04 XC70;97 965
jimmy57 wrote: 15 Oct 2018, 16:36 There is a lower level. The front of box slides up, the + terminal nut has to be unscrewed. There are tabs around perimeter of the top layer you push away from the edges they clip over, and then lift the top up.
Thanks, I did try exactly this, but there must be a special tool to do it It is nigh impossible to do it with just screwdrivers and plastic wedges.
