'04 XC70 -- Detailing Product for rear bumper cover? Topic is solved
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Would like to improve the dull/faded appearance of the rear bumper cover plastic. What works well ( not interested in heat gun or Armor All)? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
I painted all my black plastic using a black plastic spray paint and then rubbed it in/off with a clean rag right away while wet. Gave it a nice new plastic look that still looks fresh now more than two years later with no additional work.
E Showell
Post by E Showell »
Thanks for the suggestion. Any other ideas?
'95 855 auto (sold)
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
Is the cover colored or black? Any paint loss from areas, or is it just a concern with the texture of the surface?
I suggest trying an auto store clay bar, with water or detailing spay as a lubricant. Meguiars has a kit with bar and liquid, available from most auto and other stores. You can also use it on the body of the car. I love the change you notice as you slide the bar, it picks up the embedded dirt and then slides freely. Ends up looking really good, too.
The clay bar removes embedded dirt that cannot be removed by regular scrubbing, and does not remove clear coat and layers of paint that an abrasive polish would. The change is the surface condition with claying is remarkable!
- Wash the bumper (or any area you are going to clay)
- Spray a small area with a small amount of detailer liquid.
- Rub the bar over the area.
- Repeat over the bumper.
- Every so often, fold the bar so the dirty side is inside, and reshape as a puck.
- Protect the finish with wax.
NOTE!
If you drop the clay, it will pick up sharp rocks, and if you use it after that you are certain to put big scratches into your car. You must throw it away.
Also watch for running to the edge of the lubricated area as the bar will stick and can get pulled out of your hand.
You can start by splitting the bar in two, and saving one half, so you have a backup.
My preference is for Zaino Bros detailing products but they are more pricey and not available locally.
erniek
Year and Model: 2004 v70
Post by erniek »
What spray paint do you use and is the bumper on or off the car when you do this?
E Showell
Post by E Showell »
Black plastic cladding (at least I think it was black at some point). Now it is faded and looking kind of tired.
'95 855 auto (sold)
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Forever Black is a plastic Dye. It will last as long as the original dye.
Cation: Make sure you do not get any dye on anything you don't want permanently stained.
Armor all, Back to black and similar products are liquid waxes that just play with the optics and don't last long.
Active
Past
EngineeringBloke
I found the same as RickHaleParker.
This 2014 consumers reports article suggest that most plastic restorers from auto shops will not last a significant time. 2 appear better than others but there is no long term report mentioned - Wipe New and Renu Finish
https://www.consumerreports.org/cro/mag ... /index.htm
In this article, Black Forever is mentioned. It looks good although I have not used it myself:
https://www.autogeek.net/trim-molding.html
https://www.autogeek.net/forblacbumtr.html
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The most ridiculous and inexpensive fix: black liquid shoes wax I've done this 2 years ago and still stays black. Perhaps not dark black like a new trim but no longer the grey-ish thing
www.youtube.com/watch?v=lspDWezi_AY
www.youtube.com/watch?v=CHMy1TlO0p0
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
oragex wrote: 31 Jan 2019, 15:45 The most ridiculous and inexpensive fix: black liquid shoes wax I've done this 2 years ago and still stays black. Perhaps not dark black like a new trim but no longer the grey-ish thing
This is great! I have thought of it but didn't have the guts to try it myself. Now I will certainly try it out.
It really lasts that long, huh?
Thanks, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
