Thanks in advance for any advice.
Oil in Coolant (AGAIN) NEED HELP!
Brooke
bpeckm
I had a problem, twice, with oil in the coolant overflow reservoir. The Turbo model (mine is a '94 850T) has an engine oil cooler built into the radiator. We replaced the radiator, cleaned out the overflow reservoir, and there was indeed a little bit of oil that came back to the overflow reservoir, due to incomplete cleaning of the cooling system. Then, a couple of months later, there was again a large amount of oil. Took the car back, they found that the new radiator was defective, and replaced it. This was all done before a 1500 mile trip that I had planned, so I lost confidence in the "fix" due to the second major oil leak, and did not make that trip. However, it has been two years (and 25k miles) since the second radiator was installed, and I have never had another bit of oil in the reservoir. So, it was indeed a faulty radiator the first time they fixed it, requiring a second "new" radiator.
