A "boing" noise from my S70
Whenever I go over a speed bump or hit a pot hole, I get a very loud "BOING" noise from the underside of the rear of the car. It almost sounds like a spring letting go. Does anyone have a clue as to the cause of this noise?
mrreilly
- Year and Model: 1998 Volvo S70 GLT
I've had that same thing happen to me. But mine sounded like the front of the car. It was right after I replaced the spring seat... I'm still clueless...
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
My major repairs:
- Has thanked: 17 times
- Been thanked: 35 times
It'll make that sound if ABS kicks in while driving over 2 surfaces which are different and braking (left side of car is on a difernt type of surface than the right). Also, if you brake as you go over bumps, it might engage.
- 2176 Views
Last post by Ou2mame
- 702 Views
Last post by TwoVolvoGuy
