Hi folks.
as the title says, I have a '98 S70 with 93K miles, on Wednesday everything was great.
yesterday it started rough, so I put it back in park and let it warm up a little until it smoothed out.
stalled at the stop sign around the corner from my house, started back up, got it restarted and kept going (work and my mechanic are the same direction).
made it to the highway without much drama, about half way it started having intermittent engine shuddering and it felt like something was sucking power away from the engine. once I got off the highway, the shuddering got worse, and while driving to my mechanic, I stalled a bunch of times (more than 50% of the times I came to a complete stop at lights or signs).
I tried to use my Bluetooth OBD reader, but it didn't pull any codes.
how bad is this going to be?
Thanks
'98 S70, 93k miles, intermittent Rough running and stalling Topic is solved
- utilityaudio
- Year and Model: '98 S70 GLT
- Has thanked: 36 times
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Could be lots of stuff. What's the current status of ignition components? Plugs, rotor, cap, wires? How old is the fuel pump relay? Original to the car? If so, I'd think about changing if for peace of mind even if it isn't producing the current problem. How are the electrical grounds in the engine bay? How old is the battery? What's it's condition?
Unfortunately, engine shuddering and loss of power sound suspiciously like burnt valve symptoms, but a burned valve will usually produce a CEL. Can you run a compression test on the cylinders? Do you drive the car in a spirited fashion on occasion or is it mostly short trips at lower speeds?
What grade of gas have you been running (please don't say regular)?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- utilityaudio
Since July the tires, battery, heater core, oil change and a tune up have been done. I'd have to look at my receipts to see if cap and rotor are part of my normal tuneup, but if not they're a max of 3 years old as I know I had them done when I had my timing belt done. Don't know the age of fuel pump and relay.
I do run regular grade gas, most driving is 50/50 highway and city, highway is typically traffic speed up to 7~10 over the posted limits, since july that's included 8-10k miles of trips back and forth between MD and OH cruising at about 75-80mph.
- E Showell
Search for the thread on here about burned valves. Lots of folks running regular have ended up with valve issues (causation not demonstrated to any degree of statistical significance). And you know what they say -- correlation is not causation, but . . .
'95 855 auto (sold)
'95 855 auto (sold)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Disconnect Maf connector,start the car and test drive it.If problem disappears...Maf is bad.
Other than that...could be a HUGE vacuum leak or FPR failure.
But,let's go one step at a time...cheapest things first!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Pretty near all of these suggestions should throw codes.
I’d start with a “2nd opinion” from another OBDll reader.
- utilityaudio
Yes, I've never been super pleased with my Bluetooth scanner and have been leaning towards getting a better device, but I don't know where to start. Seems like 98's are in kind of a grey area between using generic OBDll codes and more customized VIDA/DICE codes that started apparently with '99s and later? (this is according to what I've been told by members of a local Facebook Volvo group).BEJinFbk wrote: 18 Jan 2019, 16:24 Pretty near all of these suggestions should throw codes.
- BEJinFbk
Basic engine/emission related codes are generic.
For now, most auto parts stores will happily come
out and scan your vehicle right in their lot.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
My primary suspicions would be fuel pump relay, vacuum leak, MAF, in that order. First and last are pretty easy to test in just a few minutes.
Also, a burnt valve should cause a constant missfire which should cause a flashing CEL. Even running on 4 of 5 cylinders, engine should not be struggling to run.
Knows enough to be dangerous
- misha
Yes...these engines runs pretty good on 4 cylinders.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1551 Views
Last post by oragex
- 7667 Views
Last post by enriquepr21
- 1716 Views
Last post by 240gator
- 799 Views
- 1140 Views
