vibration felt in the body /seat under load over 50 mph, that reduces or goes away when coasting. this is inconsistent however some days it does not vibrate. vibration in the steering wheel is minimal. tires re-balanced.
I have seen posts about this and to check the half shafts by twisting the left and right shafts at their connectors for looseness.
I will do that asking if there is anything else to investigate?
2005 xc 70 vibration - 220k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Make sure to support the car properly on jack stands when doing so. May as well test the awd while there
If replacing dont discard the old driveshafts yet
Id also look at the engine mounts, google a bit about the two torque mounts
raquette
- Year and Model: 2010 xc90, 2007 xc70
- Been thanked: 4 times
I have not checked the front half shafts yet, but thinking this over also planning removing the rear drive shaft and test driving without the shaft in place to isolate the bearings particularly the center carrier bearing.
Is is ok to drive the car without the rear drive shaft in place? and for a long time?
If this is found to be the problem, I would likely just leave the rear shaft off since the rear awd system has not worked for some time and to figure what is not working in the haldex seems overwhelming.
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Check front brakes, if caliper pins are sticking that could cause serious vibration if just one pin is sticking. Does the vibration get worse upon acceleration or braking?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
raquette
vibration is only on acceleration. brakes are good.
because the vibration is more in the car body, and seats, and not the steering wheel, i think it is the prop shaft /center carrier bearing.
to cold here in ny to diagnose it right now, it's 0 degrees.
- 8697 Views
Last post by Ou2mame
- 1095 Views
- 390 Views
Last post by wuttheheeck
- 1794 Views
Last post by famfeld
- 11 Replies
- 5941 Views
Last post by breesay1
