Rear spring installation
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Daveliz99
Year and Model: V70 2001
Has thanked: 3 times
Been thanked: 2 times
Post by Daveliz99 »
2001 V70 2.4T FWD
I’m very, very frustrated. If you have experience, please comment.
Hello, I have recently taken my rear end apart for a suspension rebuild. I have my bushings pressed in and the subframe back in, and I’m trying to put it back together. I’m having a hell of a time trying to get the rear springs re-installed. I have determined that the rear lower control arms are two different part numbers for drivers and passenger side, and I have them sorted out correctly. I’m using a rented spring compressor from Autozone.
The problem is that the spring will not stay seated properly in the bottom. As I release the tension on the spring compressor, it “jumps” out of place. I have tried using the jack to hold the control arm up, I have tried installing all the other arms and links with the spring still compressed, and everything else I can think of. Can anybody chime in.
Please and thank you.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Did you Install a striker plate. Did you leave 15mm of space between the end of the spring and the raised portation of the control arm?
See the attached replacement procedures.
Rear_Springs_Replacement.pdf
(275.58 KiB) Downloaded 280 times
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Just had this problem on a '98 V70. We solved by tightening down the disk that hold the spring in place before releasing the spring compressors. If you go that route, working space is exceptionally tight.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Daveliz99
Post by Daveliz99 »
E Showell wrote: 29 Jan 2019, 17:39 Just had this problem on a '98 V70. We solved by tightening down the disk that hold the spring in place before releasing the spring compressors. If you go that route, working space is exceptionally tight.
What disk are you talking about?? Mine is an 01, are ours the same?
Daveliz99
Post by Daveliz99 »
RickHaleParker wrote: 29 Jan 2019, 17:38 Did you Install a striker plate. Did you leave 15mm of space between the end of the spring and the raised portation of the control arm?
I didn’t know about the striker plate. But yes from looking I can see that is made to control exactly the problem I’m having. It looks like I can weld one up from some scrap.
Thank you very, very much.
Daveliz99
Post by Daveliz99 »
But about that 15mm, I tried to eyeball about 15, 10, 20, 50 and zero. ANYTHING to get it to stay. If I’m correct, 15 is ideal, but if you wind up with more than that, the spring will walk itself into place after a few bumps on the way to the alignment shop. Right?
Anyway, it’s 26 degrees in the carport. I’ll try to rig up that tool in the morning. Thanks again.
E Showell
Post by E Showell »
'98 likely different from '01.
'95 855 auto (sold)
Daveliz99
Post by Daveliz99 »
E Showell wrote: 29 Jan 2019, 18:25 '98 likely different from '01.
I thought they must be...I didn’t have anything like that when I took it apart. But after a quarter million miles, I wondered if it might have fallen off lol
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
Does anybody know where to get the striker plate? Google came up empty. FCP euro does not have it either.
Thanks
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
Has thanked: 1498 times
Been thanked: 3810 times
Part 9997079 NLA from Volvo
Bend a lip onto a piece of stock, C-clamp to frame member
Open eyebolt to catch spring, tack a Thread to pick up Hole
Several thick zip ties onto base of spring
Many ways to skin this cat.
