Hello
The brake lights on my Volvo have been out for a little while and I'm trying to pinpoint the issue.
I think I've narrowed it down to be the brake light switch and I was wondering if anyone has any diagrams of the switch and the brake pedal so I can take it out of my car and test it.
Any help would be appreciated.
Thank you
Volvo 940 Brake Light Switch
falconstar16
- Year and Model: 1994 940
- Has thanked: 1 time
volvo240student
- Year and Model: 1993 240
- Has thanked: 6 times
I am having similar issue, is it only one side or both? If it one side only, test light bulb and socket.
I replaced my whole back light assembly as it was getting melted on the brake light, but still one side doesnt work.
falconstar16
The issue for me was that no electricity was getting from the battery to the physical brake lightbulbs. This caused all of my brake lights to go out on both sides of my car. Since its only one side for you I would definitely recommend testing the light bulb sockets and where the light bulb assembly plugs into the car (white plastic block with wires coming out of it. Test each little hole that plugs into the light assembly) with a voltmeter before replacing the brake light switch. If you aren't getting any charge and your lightbulbs work fine then I'd look into an issue with the electrical wiring or the brake light switch. I replaced my brake light switch and that solved the whole problem for me, but it seems like you have a different problem than me.
falconstar16
The issue for me was that no electricity was getting from the battery to the physical brake lightbulbs. This caused all of my brake lights to go out on both sides of my car. Since its only one side for you I would definitely recommend testing the light bulb sockets and where the light bulb assembly plugs into the car (white plastic block with wires coming out of it. Test each little hole that plugs into the light assembly) with a voltmeter before replacing the brake light switch. If you aren't getting any charge and your lightbulbs work fine then I'd look into an issue with the electrical wiring or the brake light switch. I replaced my brake light switch and that solved the whole problem for me, but it seems like you have a different problem than me.volvo240student wrote: 13 Mar 2019, 22:09 I am having similar issue, is it only one side or both? If it one side only, test light bulb and socket.
volvo240student
So I solved my issue, I replaced the assembly and one of the wires was not connected correctly too. Goo luckfalconstar16 wrote: 18 Mar 2019, 00:48The issue for me was that no electricity was getting from the battery to the physical brake lightbulbs. This caused all of my brake lights to go out on both sides of my car. Since its only one side for you I would definitely recommend testing the light bulb sockets and where the light bulb assembly plugs into the car (white plastic block with wires coming out of it. Test each little hole that plugs into the light assembly) with a voltmeter before replacing the brake light switch. If you aren't getting any charge and your lightbulbs work fine then I'd look into an issue with the electrical wiring or the brake light switch. I replaced my brake light switch and that solved the whole problem for me, but it seems like you have a different problem than me.volvo240student wrote: 13 Mar 2019, 22:09 I am having similar issue, is it only one side or both? If it one side only, test light bulb and socket.
- 13 Replies
- 5356 Views
Last post by S40volvo2007
- 11 Replies
- 7117 Views
Last post by Memark
- 1648 Views
Last post by reinerh
- 11 Replies
- 3395 Views
- 613 Views
Last post by voom8
