Left Headlight Stays on with Ignition Off
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mooose
Year and Model: v70 2005
Has thanked: 2 times
Post by mooose »
So, I turn off the ignition and the left headlight stays on. Tried rotating the light control switch, no difference. I have pulled Fuse 17 in engine compartment for now. Check all codes, nothing lamp related(I do have P0027). Any thoughts? I am suspecting CEM or maybe LSM, but how would I trouble shoot this. I do have the wiring manual.
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Search forum for the mosfet/chip that controls the HL bulb.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
The higher wattage bulbs (forward main and high beam halogens are fed through physical relays inside the CEM. A MOSFET may provide the lower current trigger for the relay. Keep in mind it could be the relay, they can sometimes fail 'on'. Most people short of experience in electronics repair probably shouldn't try to replace relays and power transistors that are soldered to the internal circuit boards on 2005+ P2 CEMs.
mooose
Post by mooose »
Can you buy just the relay? I presume a new CEM is worth, what, $400+?
I have not been able to search " mosfet/chip that controls the HL bulb". Site says it is too busy. :(
mrbrian200
These relays don't plug in the side of the CEM like older P2 Volvos 2004 and earlier. From 2005+ they're internal soldered to the circuit board. A new CEM is way more than $400, most people would opt to send the one they have away to be rebuilt. There's vehicle specific programming involved so you can't just pull a CEM from a salvage yard and put it in your car. If you were to try to replace the internal relay yourself you'd need to trace the circuit within the CEM, there are no internal diagrams for these.
There are pictures of the internals here:
https://forums.swedespeed.com/showthrea ... -5t-2008my
That's from a 2008 model, however they changed little between those years, yours will look nearly if not identical on the inside. You're looking at one of the relays 1-5, 8, or 9. The two big black ones 6 and 7 are 'main relays' that are tied to things like all the interior electronics, power seats, 12v power port, CCM etc.
Unfortunately I do not know which of the little relays are tied to the main beams L or R. You'd have to trace the circuit from the connector pin B-7 back to the individual relay.
These relays can be tricky to find/order, you need to stick to exact part or identical matched specs. For example to my knowledge the two larger black relays aren't available as an exact part from Tyco (TE Connectivity) without placing special order: you have to order matched spec relays and dremel the contact spades so that they fit through the holes on the board to solder them on. Like I said most people would probably opt to send it away to have it rebuilt.
mooose
Post by mooose »
Thanks for the replies. I guess I need to take it to the dealer.
Has thanked: 1505 times
Been thanked: 3818 times
Nope - you guys have XEMODEX up in Canada who will rework your CEM For a lot less coin than the dealer
mooose
Post by mooose »
abscate wrote: 15 Feb 2019, 08:56 Nope - you guys have XEMODEX up in Canada who will rework your CEM For a lot less coin than the dealer
Thanks for the suggestion.
mrbrian200
The dealer may not cooperate with the idea of 'reworking' your existing CEM. The option they're likely to propose would be to install a factory new CEM at somewhere around $1000 part + labor + programming. So you're talking a range around $1500, maybe up to $2000 just to fix a malfunctioning halogen headlamp circuit. Who would have ever thought 20-30 years ago that a malfunctioning lighting control circuit might someday be considered a 'expensive car killing repair'. But that's where we seem to be with modern vehicles..
mooose
Post by mooose »
Any ideas on how to be sure it is the CEM? I hate guessing and then buy parts. :-)
