computer
G1022
Year and Model: 2005 s 60
computer
Post by G1022 »
does anyone know how to reset the computer on a 2013 XC 90
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 24 times
Been thanked: 127 times
Post by ggleavitt »
ECM has software and learned adaptations, you can reset adaptations via VIDA/DICE (Diagnostics/Vehicle Communication/ECM/Advanced). Think you might also be able to reset the ECM adaptation values by disconnecting the battery negative lead and letting the car sit for a while (1/2 hour, maybe longer?), someone will need to confirm this. If you do remove and reconnect power, there's a best practices procedure to follow so as to avoid the possibility of module data corruption, SRS module coding or an unplanned air bag deployment.
As far as a software reset, I think this ends up being an ECM reload and to do a software reload you need the car connected to VIDA/DICE, logged in and connected to Volvo.
I might be way off but this is what I believe is the case. Not sure if that helps to answer your question.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Wat is the problem you are trying to do reset for?
G1022
Post by G1022 »
OBD will not register failed inspection
