2006 S60 lost key, options? Topic is solved
Tonkadoster
- Year and Model: 2006 s60 2.5 awd
Few other than tow and dealer
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Sorry, that's really tough. Keys are not cheap and I assume you don't have a spare?
Replacement keys have to be programmed by the dealer which is not cheap either. I'd suggest you try to reach out to get the keys back with a reward, but you would be lucky to contact the person who took them.
Good luck.
Good luck.
No known cheap fix.
Tow to dealer
I feel Yagger can do it over Dice you might save some money but it’s syill a $3-400 affair
Tow to dealer
IslandV70
- Year and Model: 2005 V70 2.4
- Has thanked: 2 times
- Been thanked: 3 times
This makes me nervous too.I actually can afford new keys, but I really would rather not have to. The local hardware store has a good key machine, they think they can copy the physical part of the key no problem. What if I hid the "real" key someplace under the dash for the code to be read and used the copies as my keys?
IslandV70
That will work , and is the cheap way to keep running in low theft areas.
You can drop the plastic cover under the wheel ( 3 T20 I think) and just tapethe key with good transponder there, out of sight
We leave our keys in our cars most nights, so that does work for us.
I put Tiles in my keys as we have multiple drivers, like 8, soon to 9 with 88 YO Mom in the T5 stick
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
My car will absolutely not let me lock the doors with a key in the ignition, not with another remote fob.. not by using another key in the outside door lock (it just pops back up/unlocks)..not by pushing the lock button on the door before closing the door.. If that 'denial to lock the car' function is tied to the CEM being able to read a key transponder (if it sees one, the only allowable way to lock the car is with the button on the door with the door shut)... then the idea of hiding a programmed key/transponder chip near the antenna ring might be a problem.
- 2100 Views
Last post by RickHaleParker
- 1582 Views
- 13 Replies
- 6478 Views
- 1997 Views
Last post by PeteB
- 216 Views
Last post by EngineeringBloke
