IPD sale Volvo Parts
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
REAR alignments
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
thomasjrsharp78
Year and Model: 2007 xc90 3.2 AWD
Has thanked: 2 times
Been thanked: 0
United States of America
thomasjrsharp78
REAR alignments
Post by thomasjrsharp78 » Mon Feb 25, 2019 4:28 pm
2007 xc90 AWD. Chewed through a set of tires, worn on the inside edge, took it to a shop and found the rear trailing arms are damaged and the sway bar end links are worn. If I replace them, do I need an alignment? Is there even any adjustment on the rear of this vehicle?
Vehicles: 2007 Volvo XC90 3.2 AWD
2012 Dodge Grand Caravan SXT
1971 De Tomaso Pantera....then I woke up.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 41 times
ggleavitt
Re: REAR alignments
Post by ggleavitt » Mon Feb 25, 2019 6:01 pm
If you look from under the back and towards the front of the car, there are two long horizontal bars that run from the center of the rear subframe to the wheel knuckles. Volvo refers to these as stays and the inboard bolts are eccentric to adjust the rear toe. I believe it's possible to adjust camber with a separately installed eccentric bushing. I recently replaced a right side stay in the '05, shop could not get the RR toe correct and you could see that it had been bent (daily driver was practicing accident avoidance, a few other parts got replaced as well). New stay and an alignment afterwards, car drives like its supposed to.
This is a 2007, could also check the rear trailing arm bushings, see this link for a visual on what these look like when they're worn out as well as one DIY version of replacement- https://forums.swedespeed.com/showthrea ... in-General , new version bushing as noted is solid now (and Ford part marked).
Copy of alignment specs from a few years back in the event there's some interest- https://www.davebarton.com/pdf/RTJ%2019674-2010.pdf
edit 022719- fix typo
These users thanked the author ggleavitt for the post:
thomasjrsharp78
2005 2.5T AWD-194k
2008 V8 AWD Sport-124k
thomasjrsharp78
Been thanked: 0
thomasjrsharp78
Re: REAR alignments
Post by thomasjrsharp78 » Mon Feb 25, 2019 6:10 pm
Yes, the damaged part is actually the "stay" per volvo, and that is what I have on order currently. So, the to is adjustable on this, but not the camber without the aftermarket eccentric bolt? So you would in fact recommend and alignment after replacing these, correct?
ggleavitt
Has thanked: 0
ggleavitt
Re: REAR alignments
Post by ggleavitt » Tue Feb 26, 2019 8:31 am
Replace whatever is broken and get a four wheel alignment. No need to worry about the camber bolt, I mention it as a matter of reference.
thomasjrsharp78
2005 2.5T AWD-194k
