Hi all, recently bought myself a Volvo V70, 2001, 2.4 170 petrol manual, with about 140000 miles.
After 5 days of ownership it came up with the low oil pressure warning, I advoided driving it with this light, aside from getting to a safe place to stop. The last time this happened it developed a rattling noise when revs increase (even when the warning was off)
Yesterday I dropped the sump to change the O rings, put it back together and noise is still there. I've not driven it like this, but it had idled for about 10 min.
Any ideas where to look?
Engine rattle when revs
BorisTheThird
- Year and Model: V70 2.4 170 2001
That sounds more like an exhaust leak than a knock but diagnosing sounds over the Internet is tough for me. I like that disappears when you lift the throttle as opposed Tom the other way, which is classic rod knock
Can you disconnect each fuel injector one By one and see if you can’t isolate it to a single cylinder?
BorisTheThird
Thanks, I'll try removing the caps tonight
BorisTheThird
If I remove cylinder no 3 it almost goes away entirely, the others make no difference
BorisTheThird
There's nothing recorded on the obd either (aside from my removing the spark plug leads)
Try inspecting the exhaust manifold close to the number three port and look/listen for leaks. You can run a bit of oil and look for smoke, too.
If there is no leak, its probably a rod bearing, which means an oil pan drop and bearing evaluation/replacement.
- Natasha
- Natasha
- 993 Views
Last post by richhodge
- 12 Replies
- 1705 Views
Last post by Sommerfeldt
- 17 Replies
- 4685 Views
Last post by Clemens
- 330 Views
Last post by lenny
- 2312 Views
Last post by lenny
