While replacing belt and front brake pads, I noticed tapered wear on all front pads. As simple fix as replacing caliper?
2002 S60
Uneven brake pad wear
Shanestrait
- Year and Model: 2002 S60
- Has thanked: 1 time
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
What do you mean by tapered? I'd replace the caliper only when the piston is hard to push back with the bleeder open. Perhaps undo first the sliders from their bushings, clean everything and use a bit of PTFE silicone grease.
Shanestrait
Tapered as in, both pads have more considerably more wear on one end than the other. If you were to look at them lengthwise.
That does not sound good - can you try post a picture?
If the piston isn't straight in the caliper bore, that is not going to end well
Shanestrait
I put it back on but here is an internet photo showing the wear I have.
https://s3.amazonaws.com/assets.knowyou ... d-Wear.jpg
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
It'd get stuck if it wasn't straight though. Based on the picture I'm guessing worn bushings causing the entire caliper to tilt when braking.abscate wrote: 18 Mar 2019, 12:45 That does not sound good - can you try post a picture?
Shanestrait
Thanks or the input so far. For what it's worth - one of the dust covers was missing.
Shanestrait
I should also note there is a fairly slight but noticable tremor when braking and also at medium high speeds.
Put a straight edge on the pad surface and see how close the metal backing plate is to the rotor. When it is within 2mm, you need new pads. Its close now.Shanestrait wrote: 18 Mar 2019, 12:49 I put it back on but here is an internet photo showing the wear I have.
- 13 Replies
- 4029 Views
Last post by WhatAmIDoing
- 5662 Views
- 1545 Views
Last post by brick_and_motor
- 12 Replies
- 2448 Views
- 1912 Views
Last post by oragex
