850 Start Up Problem
We have a '94 850 wagon (155,000 miles) that has been having a problem starting. Here's the situation: It will start right up in the morning. If it is driven only a short time (maybe 1/2 mile) is turned off, and then you try to restart it--nothing. It won't start, and it makes no noise whatsoever--no clicking--nothing. If you let it sit for about 5 minutes and try it, it will start right up again. If you drive it a long distance, turn it off and try to restart it, it will start right up as well. So, it seems to only do it when the car hasn't had a chance to warm up. Our mechanic tried installing a new relay thinking that might be the problem, but it didn't work. Now he is wondering if it needs a new starter. The car is always kept in great shape--all scheduled service is up to date. Any ideas about what could be going on?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I love mechanics who try something then something else if the first something did not work - all on your money.
Seems a drastic step to be changing the starter motor without further checks. I can't see how the semi warmth of the engine would knock out the starter motor. I would run a lead from the battery + to the starter solenoid at that time. That will tell you if the starter is the cause.
Personally, I think it is more likely to be a bad connection between the starter switch and the solenoid.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Check the battery. Have a parts store or mech do a load test on it. I had that same kind of problem with my Camaro a while back. It would start, back out of the driveway and I would shut it off, I would come back a few minutes later and no start. wait 10 minutes or so and it would fire right up. After 75 dollar bill at the shop I found out that the problem was a bad cell in the battery. After I would start the car it would draw just enough juice that if i didn't let it sit and "recharge itself" for 10 or 15 minutes, it would not have enough juice to tell the computer to excite the injectors. Just something to think about.
Own a 94 855 Sportwagon, Restored 67 Camaro RS, 60 Chevy 4x4 Mini Monster Truck
Svenska 850 Wagon
- Year and Model:
I have 157,000 Miles and I just replaced my Ignition switch in the summer. I seemed to have odd issues once and a while where I could start the car but nothing else would work (Signals, ABS, Radio). Have you tried jiggiling the key? Close mileage to mine. Just a thought. Replaced at Volvo for $140.
1995 Volvo 855 GLE 262,000Kms
1992 Subaru SVX 82,000 Miles
1981 FIAT Spider 194,000Kms
1981 VW Westfalia 164,000Miles
- 12 Replies
- 3407 Views
Last post by Jaguar xjs
- 11 Replies
- 2047 Views
- 151 Views
Last post by TV850
- 860 Views
Last post by erikv11
- 4414 Views
