Switching out the whole rear end of my 1999 volvo v70xc. AWD TO FWD?'s
V70xc1999
- Year and Model: 1999 v70 c.f. 2.4 Tu
Ok I have a 1999 V70xc awd wagon. It is no longer awd and I am sick of everything being a cluster back there and so dam hard to work on. So I want to switch the rear end out of a fwd v70xc wagon. Can I do it??? And what years can I get the fwd rear end out off. Im shure I can..its the same frame. I would think. So need to know 1... can it be done with out a welder or anything crazy..2....what years will fit.(1999-2000)? Or more. 3....what model cars will work?(assuming only the wagons?) 4....would the back end off a xc model work?( I use for carpentry so a higher back end is sometging I would not mind.)Thanks ahead of time to any answers and replies!!!!!!!!
- Been thanked: 4064 times
Just look for a decent FWD and pull off the commerce....dealing with two rusty back ends and then a custom fit....that gluttony for punishment
Look on the volvo parts webstore site to get the part numbers for the rear axle parts - one of the gurus will have to respond about if the frames for the XC and V70 series are the same. I don't think I have ever seen that discussed here or other Fora.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I'm very familiar with the rear suspension and axle set up in 1997 850 FWD & 2001 V70XC AWD. AWD & FWD rear suspensions are two very different constructs.
Unless someone says otherwise, how to mount a FWD's rear SUPPORT ARM to AWD mounting point, there is none.
V70xc1999
So it is not duable at above basic mechanical skills and with out makeing some sort of custom mounting bracket? Can I remove the rear diff and axles? I have no use for them and there just in the way. Trying to loose waight and gain space as well. I dont see how it would hurt any thing...but I may be wrong. I am very surprised that the frames are different!!!!! And the mounting points wouldn't work....I would think they would have used the same frame and just made different rear ends?!?!?!?! I called and asked the dealer ship and what they said is all of the parts for the rear end..control arm etc....where the same parts for the FWD and RWD but the guy didnt know if they could swop out...
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I'm fairly certain I've seen this discussed before, as I have a 2000 XC that is FWD (shaft and angle gear removed). The general consensus that I remember seeing is that it's a giant pain in the rear (pun?) and not worth the time and effort. I've thought about removing the axles, but you still need the speed sensor that is a part of the outer axle. Personally, I'm just not gonna mess with it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Why not just take everything and change 100% of everything that wears? New hoses, new fuel pump, new squishy bits for the suspension, etc. Probably cheaper, definitely easier, you'll have all new parts in there, and you won't have to think about it for the next 150k miles. You'll take it out of your sphere of worry, even if it is still a mess back there.
- 584 Views
Last post by wizechatmgr
- 1987 Views
Last post by Lelica
- 1888 Views
Last post by erikv11
- 4071 Views
Last post by FLXC90
- 939 Views
Last post by Hardtofool
