rightreardoorlockactuator
the right rear door lock actuator stop working.I replaced it with a 2003 lock actuator and it will unlock but not lock by remote. what is used to switch the motor direction so it will lock or do I have a bad actuator?
- SuperHerman
- Been thanked: 207 times
My guess would be that it is out of sync - try syncing the entire system (I have seen some posts on this). If it opens it means it is working. Are you sure you installed it correctly?
