Hello folks, just noticed an issue right after initial taking off. The issue is more noticeable when I had stopped and had the engine off for awhile and then take off. The car kinda starts to have intermittent 'holding' (deceleration) as if it is losing gas. It continues for about twenty to one-hundred feet then drives normally. No issue at highway speed.
Thanks
Slight Intermitent Deceleration Just After Take Off
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Oka
UPDATEOka wrote: 30 Apr 2019, 17:50 Hello folks, just noticed an issue right after initial taking off. The issue is more noticeable when I had stopped and had the engine off for awhile and then take off. The car kinda starts to have intermittent 'holding' (deceleration) as if it is losing gas. It continues for about twenty to one-hundred feet then drives normally. No issue at highway speed.
Thanks
I just noticed the light deceleration starts at about 20MPH for about 50/100feet. A little latter, the more I step on the gas the more it acts like it's going to stop. My work is about fifteen minutes from home and after about half the way home, the car started driving smoothly again.
volvodork
- Year and Model: 2001 X/C 70
- Has thanked: 1 time
- Been thanked: 3 times
Check all of your turbo hoses. I had that same issue on my 2001 X/C70 and I had the hose come off from turbo housing (good luck accessing this one on the XC—it was a PITA with the transfer case in the way!)
Oka
Thanks, I will try to locate them.
- 41 Replies
- 6674 Views
Last post by Seaway
- 68 Replies
- 11309 Views
Last post by 1ezliving4ume
- 1131 Views
Last post by vtl
- 28 Replies
- 3877 Views
Last post by RickHaleParker
- 11 Replies
- 2256 Views
Last post by wizechatmgr
