2001 S60 T5 Long Crank after sitting
Littlepug4ever
Year and Model: S60 T5 MY 2001
Post by Littlepug4ever »
Hello fellow Volvo lovers,
Well, the title just about says it all...
2001 S60 T5 LPG converted (BRC Plug & Drive), 150000 Km.
Started to have difficulties starting ii the morning a few months ago.
- Cranks for exactly 7 seconds after sitting overnight, then runs perfectly.
- If I turn it off immediatelly after starting for the first time in the morning, it will start right away, perfectly normal; as will it for every subsequent times I start it (I assume this rules out the engine temperature from the equation) :?:
- If I let it sit during the day, it will crank in the proportion of the amount of time I let it sit. My impression is that this characteristic is getting worse... In other words, a couple months ago, letting it sit for 1 h would resulta in an almost immediate start. Today it resulta in a 2-3 second delay in cranking time. Still, the biggest delay it will get is exactly 7 seconds. :!:
- The car pulls like an express train, idles perfectly and behaves, otherwise, perfectly normal.
I had trouble with a top-leaking original fuel pump in the past. Solved it with glue for 3 years, but as this issue appeared, I assumed it would loose fuel pressure through the fuel pump when sitting... So today replaced fuel pump for a new BOSCH unit... problem is exactly the same.
Running out of ideas... Can continue with the lottery game of replacing parts, but woud like a more focused approach.. :lol:
p.S. Never in this period of time has it thrown any CEL. VIDA doesn't have DTCs...
p.S. 2 Car is LPG converted... but as it won't start on LPG, can't really use it to help on troubleshoot...
p.S 3 the Battery is very good (VARTA), brand new
HELP, please?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Littlepug4ever wrote: 30 May 2019, 08:59 Hello fellow Volvo lovers,
Tomorrow morning turn the key to POS II (on no crank) wait 15 seconds then crank.
Active
Past
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
5 seconds will do it if loosing pump up as most do. put your seat belt on during this time and turn the radio down from last nights high volume coming back from the pub. Your starter will last a lot longer. What wont it start on propane? does it automatticly switch from gas to propane? Im guessing that tank of gas could be 7 years old since you only use a spoon full every start? how do you keep it fresh?
Littlepug4ever
As I mentioned, I changed the fuel pump yesterday so... No, the 15 sec delay in pos 2 didn't help the slightest bit... :|
As for the gas, I usually spend like 1 tank every 3 months so... Evenmore, I had to consume the entire tank in 1 week for my mechanic to be able to change the pump without drowning, so... :?
