2010 XC70 A/C Receiver Drier Location
maverick455
Year and Model: 2010 XC70
Post by maverick455 »
I am trying to locate the Air Conditioning Receiver Drier on a 2010 XC70. I don't see it anywhere under the hood. Anyone know where it is located?
Steve H
Year and Model: 2008 S60 2.5T & XC70
Has thanked: 6 times
Been thanked: 10 times
Post by Steve H »
Inside a tube portion of the AC condenser.
maverick455
Thank you for replying. So the whole condenser must be replaced?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
No, the drier is serviced with a kit with desiccant insert and o ring to seal the access plug.
I have used the Four Seasons one from Rock Auto and from local auto store.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
For my 2010 S80 3.2 the dryer is a desiccant bag inside the condenser.
It comes in a sealed aluminium Mylar bag and it only has a 1 year shelf life.
Don't open the Mylar Bag until you are ready to install the desiccant in the condenser.
The cap that holds the bag in place uses a Torx T-70 fastener.
I didn't check but I would think that the XC70 uses the same configuration
This is what I bought
GENUINE VOLVO 30776238 Receiver Drier Insert
If I had to do it again I would also replace the plastic cap with the O-rings and filter screen at the same time (I don't have the part number handy)
Note: to replace the desiccant bag you need to lift the radiator and Fan and then lower the cross-member under the radiator. This will expose the plastic cap with the T-70 that needs to be removed. Also don't forget to remove the R134a first.
Item #2 and #3
These are what I would replace
To remove the old bag you just need needle nose pliers or small fingers
The Bag fits inside the condenser, picture not to scale.
Good Luck
Paul
maverick455
I am replacing a bad compressor. When I purchased the new compressor, I also bought a Drier, but unfortunately got the wrong type (can type). I'm thinking since the compressor was bad, I probably should flush the system. I've read that the newer type condenser can't be flushed and should be replaced if the compressor goes bad . Any opinions on flushing the A/C system and the necessity of replacing the condenser on a Volvo would be appreciated.
pgill
Post by pgill »
When I replaced the Compressor on my 2010 S80 I also replaced the desiccant bag because I read that a clogged desiccant bag can negatively affect performance of the AC system.
And I read about flushing the system but I decided not to.
But I did carefully follow the instructions on the compressor to spin the drive pulley so that the oil would circulate prior to use.
It works fine so far
Thanks
Paul
