V70 turn over, CEL and camshaft sensor/reset valve issue
Twopointfourturbo
Year and Model: 1999 V70 2.4 T
Has thanked: 6 times
Post by Twopointfourturbo »
Hi everyone,
At first I thought this was a minor issue, but after additional headaches I thought I might ask here for some help. Short backstory, 99 V70 2.4T AWD, about 140000km/86000 miles. The check engine light/CEL started to come on sporadically a month ago, in combination with some starting issues (took about 8 seconds or longer to start, espcially at first starts in the morning). After my local garage looked at the ODB ECM readouts they determined it was a camshaft position sensor error - I decided to replace the sensor at another garage with experience on 850s and P1 C/S/V70s, this was 2 weeks ago.
After I get my moose back last week, the CEL is initally gone but the starter issues remain although different - either it starts normally on the first try (rare occurence), or it wont ever jump on at first, turning over endlessly but then starts normally on the second try. (common) At first I thought I'd wait a week or two and see if it gets better but now the CEL has reappeared, again very sporadically (a day or two at a time, with no regular interval periods) before disappearing again. I dont think the starter issues get better/worse if the CEL was on or not. After this I did another ODB readout at the second garage, getting the following codes: ECM-3000, ECM-644A, ECM-6440.
They're ECM codes concerning the same camshaft position sensor as before (ECM 3000 & 6440) as well as for the camshaft reset valve (ECM 644A) (According to the readout the codes are due to either a faulty signal or none at all, the readout didnt differentiate between both). I don't get how this could happen with a new sensor installed. The only idea I came up with so far would be to take a look at the cam reset valve and/or wiring of the position sensor and the ECM... your thoughts? Any ideas and suggestions are appreciated.
melmwood
Year and Model: 1999 V70XC
Has thanked: 1 time
Post by melmwood »
I've got a '99 V70xc 2.5T and have two camshaft position codes that don't go away (forgetting now, but something like 0340 and 0343...both reference the sensor). I've replaced the CPS twice (one cheap, one OEM) and neither fixed the codes. Idle is rough (somewhat rhythmic). Plugs and coils are new and line tested. I experience the same starting problems you outlined as well. If you came across a fix, please let me know. Wish my reply had some actual help in it, but I've gotten nowhere with this issue.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Twopointfourturbo wrote: 08 Aug 2019, 10:53 The only idea I came up with so far would be to take a look at the cam reset valve and/or wiring of the position sensor and the ECM... your thoughts?
You are on track. Shorts / opens and dirty connectors can cause two of the DTCs. Pulling the ECM, cleaning connectors and making sure it is seated good in the socket might do the trick.
Active
Past
