Is every XC70 a turbo? I think it is...
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
RocketUSA
Year and Model: v70 2004
Post by RocketUSA »
I've got some good experience with a 2002 S80 and 2004 V70, but what I can't quite pin down is if every second gen XC70 (2000-2007) is a turbo. I'm pretty sure it is, which brings me to my next point: in my research, I've learned that the turbo Volvos have potential for transmission issues, since the transmissions mated with those engines really were never intended to handle a turbo. The XC70 has a "low pressure turbo" option. Are these low pressure variety ok to run with the standard transmissions, or am I just setting myself up for failure?
2004 V70
2002 S80
Overall car hobbyist
Has thanked: 1500 times
Been thanked: 3812 times
It is easy to get a very biased viewpoint from internet research, as the people who come seeking help are those who have failures.
The 2001 Volvo is "known' for having transmission problems but that probably means a 10% rate rather than 1% failure rate - I wouldn't hesitate to buy a clean 2001 if I could start it cold, run it up hot on the highway, and it shifted fine. All these issues were put aside in the 2002-2007 years, these are solid.
I believe all P2 generation XC70s are turbos, correct.
The manual and automatic transmissions are made by AISIN who makes them for several car makes - if someone says Volvo transmissions aren't as reliable as Japanese ones, they are showing their stupid spots.
I believe in the heavier XC90 line, there is some truth in that the transmissions were overtaxed in the T6 badge with the 3.2 liter engine, but not in the XC70 line.
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
The T6 used a GM transmission. Which does not seem to have a bad rep in the configuration that GM used in their cars.. later the same six speed that was used for the P3s came along, not sure for which engines though.
Other than that I haven't really heard anyone blame failure on the torque and power. It seems to be more down to luck. Especially since non turbos also have the same occasional issues. Besides over here most late Xc70s were diesels and the transmission seems to be able to handle their extra torque just as well.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
While there, the AWD on most of these will no longer work if it wasn't already repaired. It was not the turbo the problem, the 01-02 transmissions were more fragile and had a setting switching them in N while waiting at a light, which didn't help
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
abscate wrote: 04 Sep 2019, 09:20 It is easy to get a very biased viewpoint from internet research, as the people who come seeking help are those who have failures.
+1 Captain in a Sea of Estrogen
JRL topped the list of transmission problem scientists. 2001 V70XC is a super hero car among XC70s.
To give credit, Jim was clear that if a 2001 ran well and had the neutral stop removed, it was a winner.
Im sure he saw his fair share of duds at wholesale though.
